nineoaks2004
May 21, 2015Explorer
sch911 wrote:
Im betting the battery was dead, and it took the converter a few minutes to bring it up to a usable voltage. The rig was plugged in to 120v AC right?
X 2 batteries will run down even when everything seems to be off, but you do have alarms etc. still run and these will drain the battery, then when run down it will take a bit of time for the battery to get enough charge to start to energize things. Also check the battery terminals and battery ground for loose lugs and /or corrosion
