Bend
May 21, 2015Explorer
First of all, you can’t believe the little “idiot light” panel that came in your rig. That thing is very optimistic and tells you the batteries are full at 13.4 volts, when they are actually nowhere near it (14.4 volts). It works by looking at the voltage present on the wiring, which will be much higher than the battery voltage while charging & much lower than the battery voltage when running loads. If it says your batteries are “full” while you are charging, you could be anywhere from 40% to fully charged. People that run their generator until the idiot light says “full” are only getting their batteries up to about 40 or 50%.
-Handybob
Charge for another 2-6 hours after the light indicates full and you will be almost there.
