MEXICOWANDERER wrote:
Variac + cheap transformer chargers = el maximum possible from small genset
One charger not enough? Add a second. They're cheap
Oops just a bit too much load for the 1,000 watt genset.
Dial back the variac. Dial it back at high altitude
Dial it forward to get those chargers* to climb to 18 amps each when needed.
Desulfate, top charge, you name it.
*Specifically will not work with high frequency chargers. Must be transformer type.
DIALS! THE OTHER WHITE MEAT
Personally I would not get carried away by cranking the variac up and forcing the charger into spontaneous combustion. What the charger will do at home should be what it'll do on a big-enough genset. Dial it in. If the gen gags, dial it back.
How do these hook up I read up a little on the site for them but don't really understand where they Ty in
