ZZSPIRAL1's avatar
ZZSPIRAL1
Converters and generators
I have a WFCO Ultra III (WF-8955) converter that requires 950W of input. I'm surprised it takes that much power to run, but maybe I'm missing something. Apparantly a 1000W generator won't provide enough power, which makes sense, because they're rated 900W. I have a Yamaha 2000W generator, but I like the idea of using a 1000W generator, because they're nearly 20 pounds lighter, less DBA and run longer on a tank.
I understand the converter can be switched out for one that requires less power. What's your recommendation, and what would you expect to pay someone to switch it out? What's the downside of a smaller converter?
I'm a DIY type, but when it comes to power I run the other way.
Thank you.
  • The older PM3s, still for sale, do not go into boost every time, but act more like a WFCO, needed a low battery first. The PM4s have that different, act more like an Iota.
    The 75 ampers and on up have PF correction in all versions so that they can still use a 15a circuit. It also helps with reducing gen VA amount compared with same amp, non PF corrected.
    This website is complicated, but to get the info, you need to check the pdf part of each section
    http://powermaxconverters.com/
  • OK ... I give up.
    I'm usually pretty good at hacking around on the Internet, but this time I guess I didn't have enough cups of java: Where are you guys reading on the PowerMax link above that some of their units have PFC??
    What I did notice however, is that the 55 amp PM3-55-MBA model, with it's maximum continuous power of 780 watts at >85% efficiency, just might be able to be fully powered from a little Honda 1000i generator. Wouldn't that be a sweet combination -> a 55 amp multi-stage charger being powered via the smallest Honda inverter generator!
  • Phil here ya go--where it says power factor converter :)
    http://powermaxconverters.com/pm412volt.html
    If the non PF corrected are like others at 0.7 PF then that 780 would be an 1,114VA draw
    Note Randy has his own versions like a 60 where he says no more 55s. It is very confusing! IMO ask many pointy questions about exact features from where you buy.
