ZZSPIRAL1's avatar
ZZSPIRAL1
Converters and generators
I have a WFCO Ultra III (WF-8955) converter that requires 950W of input. I'm surprised it takes that much power to run, but maybe I'm missing something. Apparantly a 1000W generator won't provide enough power, which makes sense, because they're rated 900W. I have a Yamaha 2000W generator, but I like the idea of using a 1000W generator, because they're nearly 20 pounds lighter, less DBA and run longer on a tank.
I understand the converter can be switched out for one that requires less power. What's your recommendation, and what would you expect to pay someone to switch it out? What's the downside of a smaller converter?
I'm a DIY type, but when it comes to power I run the other way.
Thank you.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
