Lantley
Jun 24, 2017Nomad
Dutch_12078 wrote:
My read of the OP is that "time2roll" has it right, and what the OP wants is basically a long 30 amp/50 amp dogbone adapter with the appropriate 50 amp Marinco style connector for his TT, mainly for use as an emergency spare in case his primary 50 amp cord is stolen. Kent and time2roll also have the connections right, in that the single 30 amp hot leg would connect to both of the 50 amp Marinco's hot terminals. The cord would be connected to the TT and plugged into the 30 amp park power outlet.
They sell/ make a 30 amp male to 50 amp twist RV cord. No need to fabricate one unless you have access to free wire the twist lock end is expensive.
