BFL13
Jan 20, 2021Explorer II
You now have two pos wires from the converter-red and blue to the fuse panel. The new converter will have one pos wire to the fuse panel.
So jumper the two pos connection points on the fuse panel (on the back usually ) and attach the one pos wire from the new converter to one of those pos connection points. The lug with the set-screw same as where the battery wire comes in allows for fatter wire from the converter.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
