samo's avatar
samo
Converting NEMA 14-30R to TT-30R?
I have a NEMA 14-30R outlet that I'd like to use to charge my RV. Can I use an adapter such as this one?
https://www.amazon.com/Conntek-Generator-Adapter-L14-30P-Connector/dp/B008TD58KW)
All the 14-30R to TT-30R adapters I've seen seem to be intended for use with generators, so I'm not clear on whether they can also be used to adapt an electrical outlet?
Thanks
  • Watch out if that 30 outlet is 240v or you could fry your rig's 120v stuff.
