CA_Traveler
Aug 24, 2013Explorer III
howardwheeler wrote:Is the gen running to spec on propane consumption? I suspect any conversion will be big $ and may involve more than just the carb.
I can't run the generator more than a few hours without it sucking a 30 lbs. cylinder dry.
Have you considered swapping it for a gas gen or a bigger propane tank? 30 lbs is a very small tank.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
