howardwheeler
Aug 24, 2013Explorer
Right now its just hooked up to the two 30 lbs tanks on the 5th wheel. I was hoping to be able to run it also off gasoline when I need it go extended times. I know they make dual fuel units, but I have not found a conversion kit. I know propane is much better from a maintenance point of view, but it just blows through propane, and gas cans are a lot easier to fill and transport than taking out the propane cylinders and lugging them to the local propane dealing, if there's one around.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
