MrWizard wrote:
don't confuse two DIFFERENT issues
AGM's don't normally out gas
that does not mean you should place them in the same cabinet as the converter or near an electrical switch that might spark
batteries and converter OR inverter should not be in the same compartment
copy that, The old battery compartment will be struck and empty, no old batteries. That's where I'm thinking the new converter will go. I just referenced two 12volt batteries stacked on top of each other for size reference as I'm hoping the deck mount will fit.
This converter is what I'm looking at.
I`m not really sure what I`m looking for in transfer switches (If both solar and the converter have over charge protection, do I still need a transfer switch) and isolaters but I may have to change to the Lifeline
GPL-6CTAGM set up as I can`t find anyone who carries the 16T
