dougrainer
Apr 18, 2018Nomad
People, READ the OP's post. He stated he checked the temp at the Relief Valve. That rules out an outside shower or anything else from the water heater to the interior plumbing. FYI, you ALWAYS check the temp at the Pop OFF valve FIRST when checking for Water Heater heating problems. IF the water is NOT scalding hot out of the Pop Off valve the problem is at the Water heater, no where else. His OHM's are correct. Odds are he has a bad tstat. But, he needs to post Brand and Model number of the Water Heater. Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
