On a recent trip in our fifthwheel the water in water heater was cool to not warm water at all. I did a ohm check on the element and got 10.9 to 11 Ohms. I also checked the water temp at the pressure ...
If there is power coming out of the switch but not at the element, the only thing left is the thermostat/high temp cutoff. They are together as an assembly. The ECO has a reset button you can check first. Page 13 here shows the t-stat.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
