MEXICOWANDERER's avatar
May 21, 2016
Correct LiPo Charge Rate?
A nearly new Dell laptop fell from (atop?) luggage storage of a car on the highway. The device broke into pieces. Screen and housing badly fractured. What a shame. They did not slow down
I rescued the LiPo battery pack - unharmed. I want to salvage it and use it to power a remote burglar alarm on my upcoming roof rack.
The battery pack says it is rated for 5300 mah @ 11.3 volts.
There are six Panasonic batteries in the pack. Each battery is somewhat fatter and longer than a standard AA battery "somewhat" means they are noticeably larger.
With my glacial internet speed I have tried to research appropriate charging voltage and safe charging current but the sites do not load. I am getting frustrated.
The batteries at present are untouched and have 11.1 volts.
What is the significance of the "11.3" volt rating? Like a 12-volt battery where fully charged means 12.7 volts? Is the 11.3 volts the voltage limit for charging? 5300 mah would a 500 ma charge rate be excessive?
I know LiPo batteries are rated 3.7 volts each so this pack would lead me to believe the 6 batteries are series parallel? I cannot imagine this size of LiPo battery having 5300 mah.
11.1 volts per battery string. Double the amp hours - meaning each individual battery is rated 2650 mah.
Is there a web site that furnishes the data on LiPo batteries? I need to configure the cutout voltage so as to prevent over-discharge.
Whoopee
  • Close to AA in size is an 18650 cell, 11v is three cells in series. If you have a current limited source, you can charge them at or just under 12.0v, or 4v per cell. You will have to bypass the internal protection circuitry.
    For safety sake, never exceed 4.2v per cell. When the current draw drops, remove voltage.
    This isn't a full charge, but close enough. You'll need a proper Li balance charger for that. Luckily Li don't need to receive a full charge, they are not damaged from undercharging like lead acid.
  • great info Jeff
    i was going to ask, what did the info plate on the bottom of the laptop say
    and suggest checking the RC web sites
    the model number from the laptop, would allow finding the correct wall wart info
    which would supply the charging volts and amps
  • As a semi-avid RC'er, the best place to look is going to be on the RC forums. I doubt you are going to find a website with battery specs tho. Even in RC land there are many different manufacturers making the same capacity with completely different C rating both on charge the discharge. What you have there is a 3S Lipo, and the charge C rating might be anywhere from .5/C to 3/C, although I wouldn't charge past .5/C since that's likely all the wall wort did, if that. I have 5300ma batteries on my helicopter that can discharge at 40C+. That's 212A discharge ! But NEVER NEVER EVER charge them like that or you will see what damage a Lipo fire really does
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
