CA_Traveler
Mar 24, 2017Explorer III
If the left end cap has a center hole then it's a SOK III, but verify.
You'll soon notice leaves sticking out the bottom of the top cover cap. They have not interfered with my CareLess operation and are relative easy to clear. Using a hex bit remove the top screws (your pic) and loosen the bottom left cover screws. Do not remove any other screws. The cover will now rotate out to the side and then use compressed air to clean. And that is also a good time to inspect the car door edge.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
