I recently took delivery of a Dynamax rev motorhome. The label on the pillar shows 65 in front 80 for rear. When I checked, the psi was 80 all around. What should the correct psi be for this vehicle. ...
Assuming you have the OEM size and load range tire... 65 and 80 would be minimums and should cover the GVWR and GAWR. Often the pressure is adjusted up (not to exceed sidewall max) to improve handling or ride and that is fine too.
Are you having issues? You can certainly try 65 in the front to see if you like it better.
Cold is before you roll and before the sun is on them.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
