I recently took delivery of a Dynamax rev motorhome. The label on the pillar shows 65 in front 80 for rear. When I checked, the psi was 80 all around. What should the correct psi be for this vehicle. ...
ALL motorhomes, the VIN/Door sticker will give the correct Air pressure for the motorhome as designed by the OEM. If you want more exact pressures you do the 4 corner weight program and then go to the charts for the weight per your motorhome 4 corner weights. The chassis owners manual is for the Incomplete Chassis build specs. That is why it states to consult the OEM added VIN sticker for the correct pressures. Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
