MEXICOWANDERER
Oct 16, 2015Explorer
When mounted in the same environment as the battery, a temperature compensated float charger is the preferred regimen except if you store the rig where the temperature is limited to say 50 - 80F and the OEM converter float is appropriate to begin with. See note at bottom
1000ma (one amp) per 100 amp hour 20/hr rate battery is enough capacity for a float charger. So 2.5 amperes float capacity is a good safety margin.
The batteries must be 100% fully charged verified via specific gravity before the float charger is enabled.
The batteries must be physically disconnected (electrically) from any possibility of having a ghost load overwhelm the float charger.
My Rolls batteries exist in an environment where the utter minimum temperature record is 67F and the maximum is 93F. I need no float voltage compensation.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
