BurbMan
Aug 21, 2014Explorer III
myredracer wrote:
....it seems like it is better to have the grommets installed on the inside because the internal air pressure forces a seal against the metal rim.
How mine are installed. It makes sense to me that the rubber washer is inside the wheel, protected from UV, and where the air pressure is pushing it to seal, vs having it on the outside where the air pressure is working against it pushing it to leak.
I never questioned the tires guys (also large national chain) when they installed them this way, it just seemed logical. I think you get enough compression on the ol' flat washer to make a seal so that a convex washer isn't needed.
myredracer wrote:
After 800 miles, the TT tires held the air just fine.
Bottom line, that's what you're looking for. I wouldn't over think it. You know the old saying, if it ain't broke, don't fock with it....
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
