BurbMan
Aug 22, 2014Explorer III
Harvard wrote:
My take on this, if the grommet is on the inside then the grommet needs to ALSO stop leakage via the threads. If the grommet is on the outside then there is no issue with leakage getting by the threads. IMO.
Good point. A typical steel valve stem has the nut on the outside so the sealing washer goes on the inside. These stems are reversed with the nut on the inside, so it would make sense that the washer goes on the outside....
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
