j-d
Aug 22, 2014Explorer II
Perhaps indirectly related, the custom brass stems for motorhome wheels (the ones form TireMan and Borg, there may be others) install with the nut on the inside. They want Blue Loctite on the nut threads. I don't think it's for sealing, but because once the tire is mounted no way to tighten the nut. Were it to work loose, that is. Can be done when nut is on the outside. My take on the Loctite is that it prevents the nut working loose (as opposed to sealing the threads against an air leak).
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
