timotb's avatar
timotb
Correctly installing a 12v power meter after coach master
I want to install a 12volt (Chinese manufactured) power monitor in my 2010 Winnebago sprinter RV ERA. Page1 of the PDF (below is the link) describes the power meter itself, page2 shows the manufacture's wiring diagram with my handwritten thinking where to insert the device immediately after the 12 volt coach master switch. Page3 is from Winnebagos online wiring schematic describing the coach master switch connections. It has 6 connections, labeled by two letters. It is my opinion that the meter should be installed between the top highlighted switch connections. KF (black) negative and LJ (red) positive. Am I right or completely wrong? Any comments?
Thanks
Here is the dropbox link to a three page PDF I made. >>> https://www.dropbox.com/s/l6x9ay1kfvgvaaq/Meter%20after%20Switch.pdf?dl=0
Having RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 27, 2025
