brn2romethewest's avatar
Jan 08, 2020
Corrugated underbelly
Hello folks!
I have a fifth wheel trailer that has a one piece corrugated plastic underbelly that needs replacing. The size is 67.75" x 17'. I have found some manufactured by RecPro but it looks kind of thin.
1. Does anyone know where I can purchase some from another manufacturer?
2. Has anyone used the 1/8" thick stuff from RecPro?
Thanks in advance,
Greg
  • RV manufacturers buy it in large rolls (36" or larger diameter) and cut to fit. Try surplus dealers in Elkhart, Ind. You might try Bontragers Surplus RV Supplies , of White Pigeon, Mich. Just north of Elkhart. Phone: 866-483-7017, Shipping wt would be low, but oversize charge. Dave
  • The only places I see it used is at RV manufacturing facilities. Probably start there. Maybe a local RV shop could guide you to a source.
  • Thank you All for the replies. I really want a long sheet. I am aware of what coroplast is. Was hoping someone knew where to purchase a long piece like 17' long.
    Greg
  • Like the others, I've purchased 4x8' sheets at several suppliers here in the Spokane area. Cut it to size, and use a little Gorilla Tape on the seams. When I added corroplast to my trailer, I supported it with several strips of angle aluminum between the frame rails.
  • I bought a 4' x 8' piece at Home Depot recently.
  • Just use Coroplast which is what recent RV's use. You may be able to get it at a local sign company and small pieces at hobby stores. Or get Home Depot or Lowes to order big sheets. It;s the stuff politicians make their street signs out of. You can get it in black which is the usual RV belly color.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
