NinerBikes
Jun 28, 2014Explorer
hmknightnc wrote:
You need to look up the manufactures recommended charge profile from their website but 14.8 volts with temperature compensation should work just fine for those batteries. Personally I would set equilize to 15 volts ( not higher to protect RV electronics) every 30 days and lose the bady 12 volt battery.
Opinions will vary
I would do this, and I would verify the voltage of a fully 100% charged battery at the battery terminals to be 15.0V, not what the charge controller says it's set at, there are voltage losses from line and length of copper wire run.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
