hammick wrote:
The Costco and Sams Club GC2s are Interstate branded and made by US battery. They require a 15.3 volt absorption charge which is no easy task. Your stock converter or stock solar charger controller will mean a short life. If your are going to go the GC2 route you have to study up on the getting them properly charged and buy a good solar charge controller and probably something to properly charge them when it's cloudy or in the winter.
Interstate GC2 charging specs
Setting your charging system up correctly makes more of a difference in battery life in my experience than does the brand you purchase. Unfortunately, that isn't always easy as they put garbage converter/chargers in from the factory. My current rig came with a PD 9280, which is pretty much garbage, no adjustability, and of course poorly installed by the trailer manufacture which makes it even worse. On the plus side, I do have my solar charge controller set up right for my Interstate batteries. You also have to keep in mind that things like the electronics of my Norcold Refrigerator have max voltage limit of 15.4 volts, so you have to make sure your set up to not go above that when it gets cold if you're using temperature compensation. While I only used solar maintainers on my two previous rigs, they were big enough to fully charge my batts once the battery switch was turned off, which went a long ways towards giving me good battery life since I couldn't plug my trailer in to fully charge in the storage lot.
Keep um wet, fully charge as often as possible and you can generally get good performance for a lot of years.
