Salvo
Sep 11, 2014Explorer
Costco GC2 spec
I decided to replace the old GC2 batteries (4 years old). Costco's GC2's are now labeled Interstate Batteries. There isn't much data on the battery, just RC = 107. A "real" Interstate battery that ...
mena661 wrote:Thanks,I have a power supply that can adjust amps. what would you suggest ( I also have 200 watts of solar,& the rv stays charged.)cdcorpe wrote:The el cheapo power supplies that I speak of only have a voltage setting, no amps setting. The battery will determine the amps and at the higher SOC's, there won't be that much going in. Tapering happens quickly.
Thanks for the advice , what should the amps be set at?
