Gale_Hawkins
Nov 02, 2013Explorer
The funny part all the old battery chargers did charge at 15 volts as amperage approached zero.
My favorite charger has become a 6 amp @ 6 volts and 2/6 amp@ 12 volts $30 manual charger from TSC.
Overnight set on 6 amp/12 volts the rate of charge will drop to 1 amp UNLESS the battery is failing. The charging voltage will be approaching 16 volts.
One side effect is the battery is equalized.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
