theoldwizard1
Oct 17, 2018Explorer II
Big Katuna wrote:
I would like to replace these with either two 6V or two 12V maintenance free AGMs.
Which ever size you choose, make sure it is a TRUE deep discharge battery. Not a starting battery and not a "dual purpose" battery.
Big Katuna wrote:
What we DO do is leave the RV plugged in all the time with AC on low, which fries the GC batteries.
First, see if your converter/charger has a setting for AGM. Likely is does NOT ! Disconnect your converter and connect the DC power distribution panel directly to the house battery bank.
Buy a GOOD battery charger that has an AGM setting. Near where your original converter charger is, install a 120VAC outlet. Buy a cheap MECHANICAL lamp timer. Set it to run for about 1-2 hours per day. Plug that into the new outlet and plug your new charger into that.
When you go on the road, just plug the charger into the other open outlet !
Big Katuna wrote:
Are there direct replacement size wise for GC batteries?
Yes, they make GC2 AGN batteries.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
