Old-Biscuit
Jul 03, 2016Explorer III
Tough to change quality of water source when it is 'well water'
Filtering the water to get Iron out can be very expensive.
If you that zinc anode rod is 3/4" NPT threads and less than 9" in length it will fit in your Suburban water heater.
Use of a zinc rod and routine drain/flushing of water heater will minimize the sulfur smell
You may need to 'treat water heater' with a vinegar soak AFTER you leave that CG
But as long as you are there using that well water.......zinc and drain/flush
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
