wa8yxm
Aug 17, 2017Explorer III
myredracer wrote:
Have had an AGM battery (one) for a year now, not that being AGM necessarily matters. Never dry camp. Also bought a Progressive Dynamics converter/charger upgrade for it. Recently installed an LED voltmeter display to keep tabs on the battery.
Voltage normally floats correctly at 13.7. If I shut the charger off, the battery stays at 13.7 volts for a bit then starts to drop slightly. I believe this is normal? Haven't left it overnight to see what it levels off at but assume it should level off at about 12.7?
Not sure what your question is unless it is a 2 parter
IS this normnal: YES
12.7.. Actuually 12.6 but depending on the meter 12.7 us good,
Unless you know how to calibrate the voltmeter. Or have access to a calibration lab that can do it for you.. I'd call that Normal
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
