GordonThree
Aug 17, 2017Explorer
pianotuna wrote:
In your shoes I would use the wizard to reduce the voltage to 13.2.
X2 on this.
Does Progressive have a temperature compensated option? There's no one voltage that's best for all situations, so aiming low is the safest option to protect the electrolyte.
In 100 degrees summer weather you want lower floating voltage, in 40 degree fall weather you want a higher voltage.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
