Whangler wrote:
Used to travel without my cpap and be okay, but have found I must now use it all the time. BTW, I'm mostly dry camping and have 350 watts of solar available. Trailer has two 6 volt golf cart batteries.
There appears to be 3 choices for me to power it:
1. Buy a cpap battery pack for ~$300
2. Wire and fuse a dedicated 12v line direct to the 2 6v golf cart batteries.
3. Just plug it in to the inverter.
What's the best way to power the CPAP?
Thanks
do you need to use the the humidifier ?
if so, you will be forced to use an inverter unless your cpap will humidify on 12 volts ..
