kerrlakeRoo
Jun 03, 2018Explorer
Have you already purchased this battery? If not . check your CPAP. If it uses a brick in the power cord at home, it likely is actually using 12 volt power and you could run it direct from your RV battery.
Better to put the money for the Pilot 12 into a second battery for the camper and permanently install at least 100 watts of solar and have use of the power for other things as well.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
