kerrlakeRoo
Jun 03, 2018Explorer
MrBiggles, with 2 6v golf cart batteries you have over 200 amp hrs available, the Pilot 12 plus has 19 Amp hrs.
Your existing batteries are much more capable. If you are truly afraid to use the same batteries that power the rest of your RV, get an additional 100 Amp hr AGM put it in the pass thru and use it with 100 watts of solar. You would have more power available, and the ability if you experience long rainy spells to switch over to the main batteries in a pinch, as well as being able to charge with jumper cables from the tow vehicle.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
