Harvey51's avatar
Harvey51
cracked elbow in plumbing
Our kitchen sink is on the opposite side of the motorhome from the greywater tank, so the sink drain goes in the floor to the other side. The elbow connecting to the long straight pipe is cracked and leaks like crazy. I can pour a cup of water in the sink, then run underneath and catch it! I cut off a dollar bill size piece of the aluminum sheet under the floor and this view is straight up into the floor . . .
There is 1/8 th inch plywood above the aluminum and it is very wet in the area but the 2x2 ribs seem to be fine. Heavy plywood floor above the ribs. I'm not familiar with ABS pipe so any advice is most welcome! Is there a magic way to take the elbow out or repair it in place? Looks like Dremel and chisel work to me.
It strikes me that the whole thing is a design error - there shouldn't be a 12 foot rigid assembly of pipes and fittings in a motorhome which flexes quite a bit. I think the best approach would be a rubber hose joint to replace this one. Oh, the hardware actually has rubber elbows! Any thoughts?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
