kitkat599's avatar
kitkat599
dometic Fridge repair
hi, this is a long shot, but wondering if you know what hinge kit you got for this repair... the plastic hole on the freezer door, where the hinge pin is inserted, cracked on my door and i can't figure out how to repair. thanks!
  • ok just to clarify, is it the insert (bushing) that goes into the hole that is worn out/cracked and allowing the door to sag, or is it the actual hinge that is cracked.  if it is the hinge  like Ramblin Reflect came up with in a google search is what you want, if it is just the plastic insert bushings that's worn out you can get new kits to fix them also (I have to do my freezer door this winter and I did my refrigerator door two seasons ago.
    once again you need to know your refrigerator make and model then a simple search or call to a rv parts store will get you what you need.  in the mean time a couple strategically sized and placed washers can get you by in a pinch to level out the door, until you get the proper parts, if that is the issue.
    here is the insert bushing so you can compare https://getrvparts.com/dometic-2931171066-refrigerator-door-hinge-bushing/
    • kitkat599's avatar
      kitkat599
      Thanks for the reply! Not sure if you can see but the part that’s broken is the plastic hinge hole that the pin fits into. It seems like it’s part of the door frame, but I see places with screws so I thought maybe this could be swapped out.
      however, after searching around it doesn’t seem like that’s a part for sale.
      this is a dometic RM2862
      • StirCrazy's avatar
        StirCrazy
        Moderator
        ya that looks to be part of the door its self, not anything to do with the hinges.  I didn't see any parts diagrams offering door trim so it must come as a whole new door.  I see they are around 300 bucks.
        I would try build it up with epoxy, I wouldn't worry about the Vaseline as the part under the door bracket where the frame is broken away is a plastic bushing that the bolt slides into (double check that's is what it is though)  clean the area up good with 99% Isopropyl Alcohol, brace the door in the closed position really good, and then use a good mouldable epoxy to rebuild the part that broke off.  if the plastic sleeve is missing off the bottom part of the hinge pin then maybe put a piece of masking tape around it.  I hate using stuff like Vaseline as you are going to be playing with it like puddy and you get the Vaseline in one wrong spot and it is not going to be as strong as it should be.
  • Hi KitKat. I guess it would be helpful to know which refrigerator you have. You can still look for hinge replacement kits. This is just a link to a repair kit that I found by doing a cursory google search. I’m not sure it’s what you need but it might point you in the right direction.
    https://www.rvupgradestore.com/Dometic-RV-Refrigerator-Door-Hinge-Kit-p/24-2675.htm?gclid=Cj0KCQjw2IDFBhDCARIsABDKOJ4uPnKCXq8h1Ab4GoemexHSQ3l7lEyjeOG5aodJeotISgiMcvW-3mUaAqP-EALw_wcB&gad_source=1&gad_campaignid=6443097527&gbraid=0AAAAAD_tb14Q2Vqd85wu2JWpXaBTLvoEQ
    and depending on where you’re located or they do also have Mail order you might try an RV surplus supplier. A couple I’d suggest would be Bontragers surplus  or Johnson surplus they are both located in Michigan. Bontragers is always my first option for hard to find parts.
