dclark1946 wrote:
Fisherguy wrote:
OK,
No
It's a 10 gallon tank, is there any reason I can't put in a 10 gallon Atwoond They don't have anodes, right? I like the idea of being able to put in a drain valve, removing the anode to drain the tank is a PITA.
Not sure why removing the anode rod is a PITA. I remove ours after each camping trip with a dedicated ratchet wrench and socket that I keep in the cargo compartment. Draining the water heater that way allows a lot of the sediment to flush out.
Dick
And putting a 'drain valve' on Atwood will not allow full flushing.
Atwood drain hole is only 1/2" and then putting drain valve just makes opening even smaller
