swimmer_spe
Jun 25, 2020Explorer
wing_zealot wrote:
Jack up the trailer slightly at each corner, one at a time, stack lumber under each corner, make sure each corner is level with the others, set the trailer down on the stacked lumber. Doesn't have to be exactly at the corner, can be in a couple of feet, whatever works out best for supporting the trailer. Personally, i would but cribbing under the axles also to keep pressure on the axles where the load was originally intended. But be careful where you crib the axles at, you don't want to bend them.
How do you level the trailer?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
