BFL13 wrote:
I really like my T-1275s. Four of those would be awesome. I think two would be enough in summer, with four being needed in winter.
I keep the 450AHish bank going all summer on solar using about 100AH a day. So they really only get down to about 85% most days, since the solar keeps filling them up faster than we use them. It is not easy to measure just what AH a day you really use. I do that with my 255w panel in the tilted twirler contraption.
Some math--at that place in May no clouds a few years back with a 130w panel I ran tests and measured daily AH from solar as:
Flat-56 AH
Tilted up aimed South all day-70 AH
Tilted and twirled toward sun during the day-90AH
So my 255w would do
Flat- 110AH
Tilted South-137AH
Aimed- 176AH (so the 255 in the contraption easily handles our 100AH daily usage even with mixed sun and clouds nice summer days)
However, to do that test I had to keep the battery voltage from getting up during the day (ran loads) and choking off the incoming AH, so it is hard to get an accurate idea of how it all works, which depends on how much the RV is using during daylight.
If you do all your AH use at night, then your solar can only do the batts and will have excess AH in the afternoon that go to waste. That is a good time to recharge your laptop or whatever chores you can invent, instead of doing it at night.
It is not always worth it to have more solar, once you have enough. On overcast days it doesn't matter how much solar you have, you get very little. It is worth some over-panelling of the MPPT controller like Morningstar recommends because although you can't use it all at noon, you do get more in the early morning and later afternoon, so overall you get more AH in the day. But just adding panels as such is a different thing.
I can't say how many watts would be good lying flat on your RV roof because that would depend on the time of year and your latitude. I can tell from my figures that my 255 would do us as a roof- mount flat with that 110AH, but I would rather have more to be sure. I would be happy with two 255s flat, which would get us about the same as the one does now in the contraption.
So about 500w would be more than adequate in my case. Total waste of money and effort to get more than that. (For us !!!---could be worth it for somebody else doing things differently)
EDIT I forgot you asked about a converter. IMO just use the RV converter, whatever it comes with, for when on shore power. On shore power you don't need solar either. For battery charging using the generator, use a variable voltage (to meet any battery spec) high amp charger as big in amps and VA draw as your generator can run, and which the battery bank will accept at 50% SOC. the object is to have the shortest gen time to restore the most AH.
Eg, I use the old single voltage 13.8v Parallax 7355 converter that came in the RV as the converter, but use PowerMax variable voltage chargers (modified converters, so they could be your converter too if set-up that way instead of using them as portable chargers.) I normally do 50-90s starting at about 155 amps with a two hour gen time window at the provincial park. I have to cheat a bit and go about 15 minutes over, but the rangers can't hear me anyway what with their chain saws being so loud! :)
When on generator, I just plug in the shore power cable and charge batteries using the RV converter (which on the new 5er I think would be a 3 stage, but will check, I had replaced the legacy one in my Jayco) - are you suggesting it would be better with a separate charger? I've seen threads on this, but that's probably overkill for what I would occasionally need to top off with. I was primarily asking about the converter if going to AGM, but I think by switching to the 4 T1275's I will manage temporary heavy loads on the inverter nicely. For the solar, I already use a Rogue 30 amp MPPT controller for the single 250W 24v panel, plus another separate 30 amp controller for the legacy 290W 12v array. My thinking was to consolidate to a single 24v array (say 3 or 4 x 250w) or keep the single 250w 24v panel, and replace the old 12v array with a new 36 or 48v one (2-3 x 300w).
