RJsfishin's avatar
RJsfishin
Critisizing New Solar Install By Proffessionals
A well known neighbor camper had a 280 watt solar install done yesterday.
A few things surprised me,....
The 2 Kyocera panels (brackets) were glued to the rubber roof, no screws.
The BlueSkys MPPT SB 3000i controller was mounted 15 ft from the 4 6v batts, thru 22 ft of 6 ga wire.
The panels were connected in parallel,....which the manual plainly says parallel connections only.
Installed price of $1550 dint surprise me much.
The "glued to rubber roof", maybe ok, they should know.
The 22 ft wire to batts, could have been 5 to 7 ft, had they not elected the easy way out. The owner is upset about that.
The MPPT controller using parallel connected panels only, was news to me.
Any comments appreciated.
  • Solar Boost recommends max of 40V (absolute max is 50V) so I can see their erring on the safe side but seems like a waste of money going with MPPT here. No need for it at all. My Morningstar PWM 45A with the temp comp wire is $100 less than the Solar Boost and would allow him to get another panel. And the various ebay controllers are even cheaper. And $1550 and no screws and skinny, long wire?
  • Hi,
    I'd be suggesting he add some screws to the mounting.
    The glue won't release between the rubber roof and the mount--but the glue between the rubber roof and the wooden under structure was not intended for that kind of load.
    The installer perhaps used an ipn remote to "tweak" the charging voltages at the battery bank. If not, then I'd be going back to these "professional" installers and asking it be done.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 23, 2026
