SoundGuy wrote:
Brilliant idea :B ... I already have my PSW inverter mounted in the front storage compartment, no reason I couldn't also locate a second converter in there as well. I'd leave the trailer wired as it is with the WFCO and just turn it off but if / when we ever sell the trailer simply remove the PD. Since I "know a guy" I can get a 9260 for less than the cost of a CTEK 25000 ... seems like a plan. Thanks! :)
That does work and is exactly what we're doing.
My main problem is that when boondocking and before I turn on the inverter, I have to be sure to go outside and unplug the converter/charger in the pass-thru, as it simply plugs into an existing 120VAC socket I had previously installed there. The WFCO's breaker is more convenient. But if your inverter/shore power 120VAC lines are separate, that wouldn't be an issue.
