CJW8
Apr 04, 2016Explorer
2014 TH and you are running the Gen for the first time and when you really needed it? Most folks bring home a new RV and make sure everything works. THEN it should be exercised regularly. I run mine monthly. Start with no or light load- Let it come up to temperature (5 min or so)- Apply moderate to heavy load for a few minutes- Remove load and let it run unloaded for about 5 min. Shutdown.
Do this and it's more likely to run when you need it. Or don't and discover it doesn't work right when you need it most.
Had you done this when it was new, it's likely the dealer would have found the problem and fixed it under warranty. Now you'll likely have to pay to get it fixed.
