Harvey51's avatar
Harvey51
Curious sink behaviour
After filling the freshwater tank for a trip, I ran water in the bathroom sink. It didn't drain - filled it about a third full with no plug in the drain hole. I figured there must be a block in the trap and got some tools ready to take it apart. Before crawling under to open the trap, I used a sponge to take out the water in the sink. When finished, I noticed there was no water in the drain hole. More water from the taps did not accumulate. Finally, I drained out the little bit of water in the grey water tank, put a 4 Liter pail under the drain, then poured a same size pail of water into the sink. It all came out the drain.
No problem with the sink on the 4 day trip.
Why did the drain not work in the first place? Some weird air block?
  • bdpreece wrote:
    In RV's rather than plumbing each sink into the vent stack they use a vacuum breaker mounted under the sink. It sounds like yours is sticking.
    X2 somewhat common occurrence
  • In RV's rather than plumbing each sink into the vent stack they use a vacuum breaker mounted under the sink. It sounds like yours is sticking.
  • MEXICOWANDERER wrote:
    Whoa! Sounds like that first load of water was WAY too hard!
    :B
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
