tenbear
Apr 27, 2016Explorer
jarata1 wrote:
What we be the best way to cover the exposed wires would electric tape around each wire do it or should I wire nut each wire
If it's a 12v wire I would use wire nuts to reconnect the wires and then cover the connection with electric tape. If it is a 120v wire, Romex, I would enclose the connection in a standard electrical junction box, making sure to clamp the wires in, and make the connection with wirenuts.
If you are just covering the wires without reconnecting them, I would make sure the wire is disconnected from the power and pull it out if possible. If I couldn't pull it out I would cut it short so it cannot be reconnected. On the other end I would cut off any sharp ends and just leave the wire there. Taping it up wouldn't hurt.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
