jarata1's avatar
jarata1
Cut wire in travel trailer I have a question
I was doing some work in my new to us 15 ft travel trailer .While cutting the wall i cut an electric wire in half.
My question is its towards the back of the trailer and it seems the only thing that isnt working is one outlet.But i aloso noticed my tail lights arent working.Im not sure if they were working before i did this because we are renivating it.
Long way around to ask does the inside electrical have anything to do with the tail linghts.
  • Your inside outlet power is 110V.
    Your taillights are 12V.
  • The wire to the outlet is 3 conductor romex. Should be easy to identify that. The wire(s) to the light are separate wires and probably run in the frame, under the trailer. But they could run anywhere.
  • your trailer wires should be brown ,green yellow and white , find both ends and do a proper repair.
    No. You've cut more than one wire.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
