69_Avion
Nov 03, 2013Explorer
IBcarguy wrote:
Thanks guys, your suggestion to replace it makes sense. I just crawled under there and the cable is only about 7' long and goes into a long box bolted to underside of the frame. Looks like a an easy job to just replace it.
Buy the right length of 7 conductor wire and make sure you get the heavy duty wire with the #10 black and white and the #12 Blue for the brakes. Everything else should be #14. Also, make sure you put the new plug on the correct end. If you do it backwards you are going to have a heck of a time getting the wires to line up in the plug.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
