Sam_Spade
Sep 15, 2019Explorer
dougrainer wrote:
A proper Battery Maintainer will not outgas.
I THINK THAT IS WHAT I SAID.
There is a reason that good Battery Minders cost a lot less than the Harbor Freight cheap ones. Doug
And for the second sentence......I think you meant MORE not less ??
Then....there is a difference between outgassing due to electrolysis, which is what produces H and O.....and WAY overcharging and getting the battery HOT so that the acid solution gives off FUMES.
The corrosion is caused by acid fumes, not the gasses produced.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
