I had my dash a/c checked out in December. They replaced the compressor, high and low port fittings, a section of ac hose, receiver/drier, and a new condenser fan. Also they had to replace the condens...
The Condensor fan is activated by the AC system pressure switch. NO correct pressure and NO condenser fan. IF you have a fan that blows a 20 amp fuse, REPLACE THE FAN, never install a larger fuse. That will cause melted or burnt out supply stream components. Doug
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
