My dash AC stays on regardless of the switch setting. The compressor appears to stay engaged all the time. It's a 2006 HR with Workhorse 8.1. Where do I Start??? Thanks for any help.
Washtubman: I also wanted to add that if,initially, your ac system ran out of refrigerant and, for some reason, the compressor didn't cycle and turn off, the compressor would continue to run without adequate oiling until it blew up. Not sure about my next statement but I believe a lot of the ac units installed in larger rvs like class A s are actually systems from major auto manufacturers like GM. Check with your rv manufacturer as to what system they install.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
