Washtubman's avatar
Washtubman
Dash AC Problem
My dash AC stays on regardless of the switch setting. The compressor appears to stay engaged all the time. It's a 2006 HR with Workhorse 8.1. Where do I Start??? Thanks for any help.
  • Could it be because you have the heater set on the defrost mode?
  • j-d's avatar
    j-d
    Explorer II
    This Link is "A" Workhorse Manual. Maybe matches yours, maybe not. I found the A/C Compressor Relay in the "outside" fuse box and it's pictured as a square relay, looking at it from the top. Is this thing a Cube. around an inch on a side? If it is, could well be a "Bosch Relay" and here's the wiring diagram for it. If yours has five terminals, there should be continuity between 30 and 87A with the relay out of the vehicle. Out of vehicle, between 30 and 87 should be OPEN. 85 and 86 are the coil that pulls the relay into contact, so there should be continuity across them. If you have test leads, you can put 12VDC to 86 and ground to 85. Relay should click and then 30 and 87 would have continuity. 30 and 87A would now be OPEN. Not every Bosch has five terminals. If it doesn't then just disregard what I said about 87A.
  • If you reinstall the relay, does it start up again? Possibly fused relay contacts? I had that on a previous motorhome.
    Matt B
  • That includes off. And it is a new development. If I pull the relay it stops.
  • j-d's avatar
    j-d
    Explorer II
    Washtubman wrote:
    ...regardless of the switch setting...
    Does that include OFF?
    Do you know that this is a recent development?
    Or could it have been this way all along and now you've noticed it?
    I ask since many vehicles run Compressor pretty much all the time. They depend on you changing the Temperature setting to get Heat, Cool, or Moderate.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
